Oil level
Old 06-12-2006 | 11:15 PM
Rick51's Avatar
Rick51
Account Deactivated
Default Oil level
I have an 06 Ultra with 188 miles on it. I check the oil everytime I ride. (hot engine). I just checked it after a nice ride. Let the bike sit for 45 minutes, checked oil and it is on the add mark. I'm being told that is ok. Was told you never want it to the full mark. My oil pressure also drops some as the engine gets hotter. Is this normal? Am I paranoid about my oil? Thanks.
Old 06-13-2006 | 12:16 AM
SubZer0's Avatar
SubZer0
Default RE: Oil level
First check on jiffy stand on level surface, oil level should be to full mark when hot, half way up when cold. You what to keep it full, the oil is needed to pull heat away, if low, the oil remaining oil gets hotter thus more heat remains in the engine. To much oil and it blows out the vents. Yes oil pressure will drop as the oil heats and thins.
Old 06-13-2006 | 09:28 AM
Longtimegone's Avatar
Longtimegone
Rick, you don't want to wait 45 minutes to check the oil. Then it is neither hot nor cold. Read your manual for the proper procedure.
Old 06-13-2006 | 06:15 PM
sleepneagle's Avatar
sleepneagle
Always check the oil hot on level surface using Jiffy stand. The oil pressure drops at idle with a TC88 engine. As you increase revs the pressure will increase. However, the Harley engine design is not a pressure design but a volume design. It is a dry sump system.
hdrider1
Milwaukee Eight (M8)
16
05-03-2019 07:51 AM
Pale Horse Rider
01-15-2015 01:05 PM
albngore
04-30-2012 12:22 AM
fireaxxe
11-20-2010 02:15 PM
nofxd
11-29-2007 07:45 PM
