Air Intake Questions
RE: Air Intake Questions
Get the Ness stage 2 Big Sucker kit.............that will give you what you are looking for.
The stock air filter and air box is super restrictive, it only has 2 openings for the air to get in. When you go to a high-flow intake, you loose all the plastic backing plate, and the whole filter is wide open to allow much more air in.
Steve
Steve
The Ness and SE are pretty much identical. Cover should fit fine. According to my service dept., K&N now makes the elements for the SE intake. Never checked on Ness, but would guess probably the same filter. Price between the 2 would be the only thing to consider. Never have priced a Ness.
I've been hearing a lot of good things about these A/C's http://www.tpeng.com/scramjet.php and they look pretty cool.
ORIGINAL: jonah
thanks guys! now my only delima is i really like the look of the stock box cover. any suggestions there?
The Ness is better as the vent tubes are molded into the backing plate, so there are no rubber tubes showing like on the S/E kit.
The S/E kit is about $150 from the dealer, the Ness Big Sucker is $99 from Eastern Performance........and that is for the chrome backing plate.
Steve
