Hit in the ankle with the passenger pegs
Old 06-13-2006 | 02:06 PM
Otisroundtree's Avatar
Otisroundtree
Default RE: Hit in the ankle with the passenger pegs
You guys really need to log more parking lot time...it is so easy to use throttle and back brake and your feet never touch the gorund. I have never watched the ride like a pro videos but I heard it's the same concept...my uncle rode highway patrol breifly and gave me the technique...I practice it and use it all the time...it seems so much easier to grab front and keep your feet on the boards but if your sitting up right light you should be it should not be hard after practice to swing your bike into any parking lot without ever touching feet toground...another major danger is oil spots...that is the only tim I am looking down is in parking lots, gas stations and stop lights! RIDE SAFE!
  #32
Old 06-13-2006 | 02:20 PM
Peekaboo Bob's Avatar
Peekaboo Bob
I actually meant front brake. I know it's not technically correct, but I've been doing it that way for 30 years in certain circumstances (straight manuevering), though I use the rear brake for slow speed cornering.
ORIGINAL: ricoman
I hope Ultrageezerglide meant he uses the rear brake in very slow manuervering. Using the front only will dump you over in a heart beat. Try the Ride Like a Pro video for good slow moves, also MSF.
There are time when you walk the bike forward. Have you ever pulled in you garage or a head-on parking space shut the bike off, and realized you were a couple feet away from where you wanted to be? Would you restart the bike to move it 2 feet?
  #33
Old 06-16-2006 | 03:09 PM
Garrison1383's Avatar
Garrison1383
I had this problem when i first bought my RK...... but after awhile i just got used to it. Plus if i ever need to walk it in reverse and its a problem i have her get off and fold them up.......... Also on some of the floorboards there are height adjustments and I put hers in the highest position which may help a little
I almost ALWAYS ride 2 up
  #34
Old 06-16-2006 | 04:12 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Pain can be a very good learning aid.
Leave your feet out and have your foot catch the ground while you're moving. That pain you feel when you wrap your ankle under the passenger peg / board should be enough to remind you in the future to either use a more wide spread stance or get the mothers off the ground when moving.
The most dangerous part would be to have your foot down between the bike and a sharp angled curb. You could literally be stuck between a rock and a hard place. An almost guaranteed broken bone.
  #35
Old 06-16-2006 | 06:02 PM
Neckball's Avatar
Neckball
It works. I'm a new rider (1 year tomorrow) and one thing I've learned is no front brake in parking lots, it only gets me in trouble. The rear brake / friction zone / clutch technique works. The more I practice it the easier it becomes.
heybaylor
03-09-2019 01:49 PM
Bluraven
07-17-2014 12:10 AM
sinnersaint
2014-2023 Touring Models
03-14-2014 09:36 PM
NVERL8
06-17-2013 10:12 PM
p51bombay
08-17-2010 08:23 AM
Quick Reply: Hit in the ankle with the passenger pegs
