Stretched Hard Bags
#31
RE: Stretched Hard Bags
ORIGINAL: deford
I'm also looking into stretched bags. Klock Werks only does fiberglass bags...won't work with the ABS bags on my Street Glide they said. They also charge $550 to glass 'em. I think I'm going to go with Milwaukee Baggers and use my own covers. I contacted them and they said my covers and hardware will work. I might put some Chrome Steel Plate on the bottom...any thoughts?
I will put a pitch in for the deep bags rather than the extensions. The extra space comes in handy. The extra space doesn't look like much but it comes in handy for large objects that would not otherwise fit in the bags and is a good place to carry tools and spare parts for long trips. I have the liners for the standard size bags that slip in. I store the tools and parts under it and have all the room of the stock bags inside the liner. I would guess that by the time you do all the body work to attach the extensions you are getting close to the cost of getting the deep bags.
#33
ORIGINAL: deford
#34
ORIGINAL: Rastus
I know this is an old thread and hate to dig it up. I'm interested in installing the fiberglass extensions on my ABS bags. I was just curious as to how they hold up especially at the seams. My first concern would be the different expansion and contraction characteristics of the two different materials. Does any one have these extensions installed for a period of time that can report their findings good, bad or indifferent ?
While your concern is well justified, the longevity of the bag, extension, and material should not be a problem if the process is done correctly.Whencompletedproperly(like theprocess recommended by lickmstickmman), we have not seen nor do we anticipate any longterm issues.
ORIGINAL: PapaTravis
Do you think it would be possible to add a diamond plate bottom to the bags, cut to fit? Seems like if you were to attach it with some sort of epoxy, it would hold fine, and if you did happen to scrape them, you could just replace the plate, and not need a repaint.
ORIGINAL: Fast Eddie
I will put a pitch in for the deep bags rather than the extensions. The extra space comes in handy. The extra space doesn't look like much but it comes in handy...
#39
I been going back and forth between Milwaukee Bagger bags (they are local) and Bad Bad bags. I am leaning towards the Bad Dad bags since I like the look better. My concern is having someone cut the holes right for the exhaust. When you see some of the pics in mags the cut in the fender and the bags don't line up. I may be too picky, but I think it's in the details.
I also been thinking about what I want to do with lights? Either in the bag or on the fender?
NorthEnd
10-23-2013 09:26 PM
06, bad, baddad, baggers, bags, custom, dad, fiberglass, milwaukeebagger, motorcycle, saddle, saddlebags, streched, streetglide, stretched
