Nitrogen for tires
Oxidisation of the rubber inside the tyre is bad, but the oxidation of the rubber outside is fine??
How do valve stems last longer?? Arent they about $3 for a set anyhow?
I have a 74 Cadillac and I watched when she got new boots. There was a lot more corrosion on the outside of the rim where the paint had flaked than the inside.
On the other hand i have lost count of the number of times I have switched on the news and seen a story about how some guy had his rims rust out on him going down the freeway at 85mph.
i'm an a&p and work for a major airline, we use nitrogen in aircraft tires because it's dry. oxigen is naturaly corosive, the temprature/psi and weight loads on large volume tires is a little more critical, but for your bike it seems a little pricey, but the bright side is your alluminum wheels wont corode from the inside out
I have had two valve stems on my Escalade fail in the last six months. I wonder why? Probably some cheap Chinese $hit.
