Dealer says I can'tput slipon mufflers on my 08
#51
I have a 2008 RKC, You can install slip-ons w/o any problems with running too lean. The bike will compensate for it. If you change to a hi-flow intake, w/o a re-map, then you will definitely have issues. Call around to other dealers (indy or HD) that are familiar with the newer bikes, they will tell you this.
Good Luck...
Good Luck...
#52
After much debate, I went ahead and had dealer do install on Sat for Vance and Hines Basic Slipons w/ no other mods to bike. Bike runs perfectly and sounds better than expected. I wish I would have done this sooner. Bike sounds like it should now. I will eventually do the stage 1 and download or pcV. Until then all is good! Enjoy the ride.
