Rear fender facsia SG/RG
Looking for some help on a part # for the rear fender facsia (maybe stock on the 08 SG/RG).
Seen 06 Ultra last night that had the SG brake light and blinkers with the low mount license plate and the filler/fascia between the fender and bags. Looked purdy darn good.
59739-06DH is the fascia in vivid black. Depending on how you want to install it you will need the stud plates and nuts or if you are going to use 3M tape. You also have a fendertip light hole to deal with. That does not include the tri bar light to go in either. It can be worked on the ultra with rails as well but you have to drill holes for the saddlebag rails.
Thanks Dawg,
Your number along with 53702-04A light bar and 68358-07A fender tip light might get it done.
Oh, on the rails, youre sayin drill a hole thru the fascia and keep the rails on.
I was also looking for the front of the bag rail only and found this # in black 46548-03. Do you have that same item in chrome?
Thanks again
Billy
Thanks again
Billy
chevdude
10-16-2013 09:05 AM
