jiffy stand woes???
#31
#32
#35
#36
There is a service bulletin on the newer bikes...http://www.box.net/services/ipaper_b...red/rexckaoutx
Perhaps this will help.
#37
#38
sure it works good. so do alot of orther things on the harleys. the stock air cleaner works well, so do the the mufflers, the cams, the hand grips, and the tires etc,etc, etc. we spend alot of money on these things making them better. isn't that half the fun, making yours just a little bit better than his, taking what is basicaly a good product and making it great. just my opinion. why settle, when you can make it right.
#39
No one makes one because 90% of Harley riders know how it works, soon quit worrying about it, and wouldn't spend money to fix something that isn't broken.
#40
question answered
With help from a friend, finally measured the width of the Jiffy Stand bracket slots on both bikes. My '03 measures 1/16 inch wider than that of my '01 which explains why so much movement on the '03. For a temporary fix, I put a shim on the forward inside which made it the same as the '01 and it is not noticeable. Will keep my eye out for a different bracket at swap meets, Ebay and etc. as the shim will work fine for a while.
