who and how too change your bagger tires by hand
Old 09-03-2009, 06:42 PM
ballpeen's Avatar
ballpeen
ballpeen is offline
Another great thread, Ive been changing farm implement tires all my life, so why not the bike, I going to give a whirl. The dealers want you to think theres some magic science involved, thats why I never tried.. Thanks All TIm
  #32
Old 09-03-2009, 06:54 PM
Bigwillie's Avatar
Bigwillie
Bigwillie is offline
BALLPEEN read back a few post and click on the link, about the guy that made his own tire changer out of a car rim and some wood. very good read. Bill
Also my tires and changer have been shipped
  #33
Old 09-03-2009, 06:56 PM
Bigwillie's Avatar
Bigwillie
does anybody think i will have a problem putting on the e3`s with the cyclehill tire changer? or does that apply to doing it just by hand with tire irons. B
  #34
Old 09-03-2009, 07:44 PM
Harley99's Avatar
Harley99
Harley99 is offline
Tires come off and go on real easy if you put them out in the sun til they git nice and hot
  #35
Old 09-03-2009, 09:07 PM
PDDGM's Avatar
PDDGM
PDDGM is offline
An old trick a tire shop showed me was using starting fluid to seat a tire that was giving problems. I changed my mower rear tires and couldn't get them to seat, he tried for a couple of times and then sprayed starting fluid(ether)in the tire, passed a torch over it and man it popped and that was it, put air it em and went to mowing. Don't know if I would try that on a MC tire or not, but sometimes desperate people do desperate things.
LOL..
Joe
  #36
Old 09-03-2009, 09:53 PM
Ridewva's Avatar
Ridewva
Ridewva is offline
Joe
Never heard of that but it sounds like it works. I use soapy water as lubricant removing, and an aerosol tire mounting spray when mounting. It's very slimy when wet yet tacks up nicely.
  #37
Old 09-03-2009, 10:32 PM
captjon37's Avatar
captjon37
captjon37 is offline
Just use a ratchet strap around the tire to seat it. I used a 1" strap and it seated real easy. I changed my rear 401 to the E3 with 3 spoons for the first time a month ago and it was easy enough for me that i will be doing my own from now on. Spent $90 on everything i needed to change the tire and i found it easy to do. I don't know if the dyna beads i used work but i do know that the ride is much more smooth with the new tire.
  #38
Old 09-04-2009, 05:56 AM
ks-waterbug's Avatar
ks-waterbug
ks-waterbug is offline
Starting fluid is old school and it works, but I wouldn't recommend it! Rarely have I had a problem getting a tire to seat after installing it.. In fact I can't remember the last time I did have a problem. But, if you do the strap trick as mentioned above is the way I'd go...
  #39
Old 09-04-2009, 06:00 AM
ks-waterbug
I don't think you'll have a problem but I do think its going to take an extra length of time as its your first time! Did you get a yellow thingy? I would also suggest that you have a friend come by and give you a hand the first time. Are your wheels spoked? Cause doing a tube for the first time is also intimidating... Just take your time cause you'll get it done and each time there after will only get easier and better.
  #40
Old 09-04-2009, 07:56 AM
Egldr05's Avatar
Egldr05
Egldr05 is offline
LOL..
Joe
Check out a few videos on this technique.
http://www.google.com/search?q=seati...fficial&hs=1Nt
Rick
Quick Reply: who and how too change your bagger tires by hand
