I need help with a CVO rear fender setup
Old 08-16-2010 | 10:48 PM
Big Twi$t's Avatar
Big Twi$t
Originally Posted by Deuce Bigelow
LOL!
Thanks!
yes, while I was looking at both harnesses, I noticed the wire colors were the same and in the same positions..
I removed the pins from both (after I made a diagram of my original connector) and put the "old" connector from my 2010 harness onto the new CVO harness.
everything is back together and working!
now I just need to decide if I can live with the stock 2010 rear fender or get the CVO rear fender...
Get the CVO fender and do what I did, eliminate everything and put the Kury universal plate holder on...nice clean look.
  #42
Old 08-17-2010 | 06:04 AM
lowleveldriver's Avatar
lowleveldriver
LOL!
Thanks!
now I just need to get a license plate holder (Kuryakyn makes a lighted one) and decide if I can live with the holes in the stock 2010 rear fender or get the CVO rear fender...
Great I would have told you the same thing, the wire codes didn't change just the plug, and to change the connection. I'm glad it worked out for you
Trey
  #43
Old 08-17-2010 | 10:16 AM
Jerry L's Avatar
Jerry L
Subscribed! Your bikes are looking great guys!
Jerry
  #44
Old 09-15-2010 | 08:49 PM
VT Hog's Avatar
VT Hog
Might have to do this mod!!
  #45
Old 10-06-2010 | 05:41 PM
appliedhort's Avatar
appliedhort
4th Gear
[quote=INZANE;5807658]Hey LEOHD... here it is wired and working... go to the build thread.... its just a phone photo but you'll get the idea...
Any idea if these will accomodate the quick connect for a tour pak (holes with gromets)?
  #46
Old 12-01-2010 | 11:58 AM
moprblms's Avatar
moprblms
just ordered my parts from zonotti's website thanks for all the information guys very helpful
  #47
Old 12-01-2010 | 12:36 PM
Harleypingman's Avatar
Harleypingman
Great; take a moment a post the parts list and prices if you can. Some information in earlier posts may no longer be accurate, especially as to pricing.
Carl
  #48
Old 12-01-2010 | 01:11 PM
ericl's Avatar
ericl
looks good
  #49
Old 03-21-2011 | 10:28 AM
Melby707's Avatar
Melby707
1st Gear
Originally Posted by brypink
Draggin' up a somewhat oldie here.
I just want the CVO Fascia and LED set-up. Do I need all the other part numbers to make it work on my '09? I was thinking just theses:
Fascia, RR Fender 60465-09
Envelope/ASY/LH/RED 69383-09
Envelope/ASY/RH/RED 69407-09
Wiring Harness 70338-09
Do I need the others to complete the fascia & LED set-up?
Stud Plate Assembly 59818-09
Stiffening Plate 60919-09
Nut, Flange, Cruise 7499
Screw 3152
Thanks
Hey brypink, is there anyway you can get ahold of me i have a few questions id like to ask you?
  #50
Old 03-21-2011 | 06:47 PM
lowleveldriver
These items are what needed to attach the light fascia to the fender
Screw 3152
also for the 09 it has a different harness then the 2010. So to make the lights work with that harness you would need an adapter. I used Ride Time Technology's Trailer Wiring Adapter. 30 bucks and it's color coded to match the main harness on the rear fender.
Quick Reply: I need help with a CVO rear fender setup
