sirius radio reception
which sat receiver are you using?
also.. It would be helpful to know which state you live in.. the satellites are over the southern US.. the farther north you are, the harder reception is.
Also.. where is the antenna on the bike? I mounted mine on top of the fairing in front of the master brake cylinder, but some guys have it mounted under the fairing.. either location seems to be ok for reception. If you're in the northern US, and riding west with the antenna mounted on the north side.. your body could be blocking signal; also, trees and large buildings will block signal.
I'd make sure that the antenna jack was pushed all the way into the receiver.
http://i659.photobucket.com/albums/u...erPA/dash3.jpg
If your using that little stinking antenna that is magnetic based, it has a magnet for a reason. It needs a minimum of 6" by 6" or so metal surface to be a ground plane for that antenna to have any gain at all. Inside my fairing I have a metal plate mounted off the front and forward of my radio, and the XM antenna sits on it. It gets rather good reception. I have thought of changing out to a marine unit ones like a fiber glass ball bat to mount on the rear bag bars or a semi unit. Both look horrid but give better overall gain then the dinky magnetic mount units.
I fooled around with the small Sirius antenna that was included with the "motorcycle installation kit" for a couple of years and could never get a reliable signal. Finally I bought this one:
http://www.antennaworld.com/satradio/
Cost about $40 deliviered (believe I bought through eBay.) I fabricated a base that allowed it to be mounted using a RAM mount to a ball mount on the handlebar. This setup always gives me three bars of signal (max on my old Sirius Sportster.)
This is what I use on my Ultra but there's no reason there would be any difference on a RK; if anything it would be even better since there's no possible obstruction from windshield or fairing. Satellite signals are very weak and almost anything can obstruct them.
