Locktite or not - handlebars
I am finishing up my handlebar install (street slammers) on my 2005 Road King Custom and just wondered if I need to put locktite on the threads. It looks like they had red locktite on them from the factory, but it could have been a paint mark. This is my first handlebar swap and need some suggestions from the experts.
On a side note, I was worried about the install after reading all the posts and the dealer estimating $800 - $1100 in labor - it was one of the easiest jobs I have experienced with the bike. It took about 4-5 hours (including time to find the tools I misplaced while working).
thanks
thanks
Loctite is a great product if you use it properly and use the right type.
I use it a lot and have never had a problem using it on anything. I mainly use "BLUE" because is holds well and is easily removed. RED is the high strength and is designed to be permanent. Is is not easily removed and usually requires the part to be heated up to break the hold and remove the fasteners.
I would use it but I would use BLUE.
Received 1,315 Likes
There are very few exceptions to using locktite on a Harley. Almost all fasteners that do not have lock washers call for locktite. The bike service manual will tell you which product (red/blue, etc) is called for. I'm pretty sure handlebars fall into the red locktite, but I'd have to check the manual to be positive.
