HK Radio FM Pre-Set Question
Old 06-10-2006, 09:08 AM
fimduc's Avatar
fimduc
fimduc is offline
Default HK Radio FM Pre-Set Question
Once you set all your FM pre-sets there is mention in the owners manual that you can scroll thru these pre-set stations using the right hand handlebar control. I have not been able to do this......when I use the handlebar control it just goes to seek mode and finds the next tunable station. I must be missing something in the set up of this function. What do I need to do to fix this situation?
Old 06-10-2006, 11:16 AM
kdietz's Avatar
kdietz
kdietz is offline
Default RE: HK Radio FM Pre-Set Question
I can only add that if you push the #6 preset for a couple of seconds, all your presets will scan for 8 seconds each....if you want to stop on one, hit the handlebar up button to select that station....I still haven't be able to switch between presets from the handlebar.....there must be a way to do
Karl
Old 06-10-2006, 11:26 AM
lschultz's Avatar
lschultz
lschultz is offline
I read something on one of these forums where they were talking about it but I done forgot [sm=jawdrop.gif] where I read it. I would be interested in this to. I don't play the radio that much but I would like to know.
Old 06-10-2006, 11:34 AM
fimduc's Avatar
fimduc
fimduc is offline
hopefully somone will know.................it makes total sense to be able to toggle quickly between your favorite FM stations and do it from the handlebar.............the hold down #6 may be a bit of a work around but I am not a fan of having to reach up to the radio very often.
Old 06-10-2006, 02:59 PM
Rhinohd's Avatar
Rhinohd
Rhinohd is offline
I was wondering the very same thing. I asked my dealer and they have been trying figure it out with no luck.
Old 06-13-2006, 06:13 PM
wldhogn's Avatar
wldhogn
wldhogn is offline
I don't have a Harley radio anymore but my Biketronics "Retro Radio" setup is controlled by the stock HD handlebar controls. Try this: Change your presets by using one quick bump (press) on the "Mode" switch (the one on the right side of the bars) followed by an "up" or "down" motion to move to the other presets. So it's a quick press of the button and then an up or down click. Like I said, I don't know if it will work on HD radios but it does on my Sony. Let me know if it works for you .. it's worth a try!!
Powderhorn09
08-29-2016 09:06 AM
Jim Dawson
06-24-2012 07:05 AM
kabuelich
01-30-2012 02:39 PM
Jtsantes
01-24-2010 12:41 PM
commander112
09-20-2009 05:21 PM
Quick Reply: HK Radio FM Pre-Set Question
