PVC and the heat management system
I posted a thread earlier about the heat management system on an early 08 SG. Now the dealer is telling me the PCV may cause the system not to work. Any thoughts on this? I was going to pull the PCV out of the system to try it, but a pain because of battery removal. See what you guys can tell me first. Thanks
Mine would cut out if I gave it any gas after EITMS was engaged. I asked FuelMoto and was told to richen the 0% throttle position at the 750-1250 (I think) positions by 3% and it hasn't cut out since. Mine is an 09. Only problem I have is I have to reactivate it everytime I start the bike.
"09 SG here with a PCV installed......Had no ill effects on the heat manangement system at all and comes on when needed. ( Although it hasn't activated since I've added an oil cooler and the "cooling" map provided from Fule Moto.) :-)
