Lowering kit? Does one exist?
They will all fit but you will not be able to put the bags back on because the kit changes the shock angle too much. If you look at the back side of one of your bags you will see what I mean as it is very tight where the shock fits.
I put some on a 06 Road King Classic and had to cut the back of the bag then do some fiberglass work. Turned out pretty sweet though.
On the down side, because the Classic is already an inch lower (just like the Street Glide) it rode pretty stiff.
Someone must make them because I have a set on my RK Classic. Not sure of the maker because I got them off of e-bay. I'm thinking it was 2-brothers, but not sure. I know that they were specified for the hard leather bags. I'll take a look and see if I can find a name on them. You might want to search e-bay in the mean time.
There definitely is a kit to do that with and I have one of them. It is a very well made piece. It does drop the shock about an inch but it requires that you drill the rivets out of the rubber peices on the bottom of your saddle bags that sit on the rail. they must be moved so that the saddle bag is moved out 3/4". then the top of the shock has to be shimmed out 3/4". I believe they supplied a longer bolt and space for this. then your top saddle bag brackets need to be shimmed out the same distance. Your not told that before purchase. I did it and it workd great.
when i had my 05 rkc .i went to eastern performance on e-bay .they sell chrome lowering shocks 1'' lower they are almost identical to harley shocks. they look and work great. at about 150.00
