RK. No Speedo, brake lights or turn sigs
I Went for a ride today and right off noticed the speedometer was not working. Also no turn signals or the brake lights. So I puckered up and made my way home. Am I looking for a blown fuse or something I should take to the stealer for warranty work? Should I remove my DFO before the Stealer looks at it?
RE: RK. No Speedo, brake lights or turn sigs
I'd vote for Speedo Sensor. Sometimes a person can get lucky and pull the unit and clean off the shavings and get it to work for a while....but it normally fails a short time after so you might be better off just biting the bullet and installing a new one. I'd also check with the dealer and see if they will cover it under warranty....you don't know until you ask!
says....
It's an inexpensive part, under 30 bucks....can't remember what I paid for the last one, but sure it was a over 20bucks. Went thru 4 of them in 2 years, the last one has lasted a little over a year now. Don't know if its a warranty item or not, the dealer can answer that one better.
To check it, is to see if the connection is good. Its held in place by a single bolt/screw.....
