Adding new Pipes, what do I need??
I知 thinking of adding a new set of pipes to my bone stock Electra Glide, I would like a bit more rumble. I致e read a lot of info on here about pipes and tuners and dynos and I think I知 more confused than ever. I only want to add a new set of pipes to my stock EFI 88, do I need all the other stuff in addition to the pipes. I知 not a performance nut, but I want my bike to work well and still maintain my 50 miles per gallon. Thanks for the help.
Any pipe suggestions with a slightly deeper rumble (not loud) would also be appreciated. Thanks again
My first set of pipes yellowed after a few months with no other mods. I added a stage 1 air filter set up and a power commander before the next set. Been running that combo for 4 years now (I did change to the bassani power curve in there at some point too). I average 44 mpg with my very "spirited" driving style.
When you change out your pipes it is always a good idea to go to a free flowing air cleaner and recalibrate the EFI.
If you are planning on putting in an entire exhaust set up and plan on doing it yourself you may need to pick up a Torx socket (not sure about your model) but to remove the stock exhaust bracket on a modern Softail you need to find a "Long" Torx to pull off the rear peg, when I did mine I had 3 Torx sockets and all three were too short.
keninnj
11-06-2005 04:47 PM
