Fairing Mounted Mirrors Yes or No?
RE: Fairing Mounted Mirrors Yes or No?
I bit the bullet about a month or two ago and installed them (that was loads of fun, my old 7.2v drill wasn't strong enough to punch through! Gave me an excuse to go to Home Depot and buy a nice one!) I was nervous about drilling holes in my fairing, but the layouts that came with the mirrors (to provide proper positioning of the holes) fit perfectly, and it turned out pretty good. I can actually see a little better from the stock ones!
ORIGINAL: SMenasco
I installed a pair of the very small "fisheyes" on my mirrors. It really eliminated all the blind spots and doesn't take away from the standard mirror observation.
[IMG]local://upfiles/1638/69468985D8DC46D795709693139C3135.jpg[/IMG]
That's the way I'm gonna go as well - have the small fisheyes on all my vehicles and they work great.
A huge yes from me - Couple of tips though - I drilled my fairing in three stages starting with a small bit then medium and then the correct size - Make sure you have exact size bit noted in the instructions - Also do not tighten the nylon bolts too tight or you can make the mirrors vibrate - I love the fairing mirrors and it did not take me any time to get used to them and I feel you can see much more then the stems - Plus you get to use the holes left from the stems mirrors for other applications if ya like - I used my left side for my Sirius radio and love it
ORIGINAL: rideon
I just installed some on my ultra two days ago. I think they give you alot better side vision, although I seem to look at about three knuckles on each hand. I followed the template exactly but I wish I had moved them up and out a bit farther. I didn't really second guess the template at the time because I figured the Moco in their infinite wisdom would have the mirrors in the perfect spot. Maybe somebody else can shed some light on the perfect location, but otherwise they work pretty good and look very cool.
Just bought an Ultra that has them on it. As far as the LOOKS, I luv it. No big mirrors sticking up on a stem. NOW...as far as what you can see? Seems to me, that you can see VERY well to the sides, but if somebody is behind me? Don't see em at all, unless they are off set to one side or another. I have learned what the back of my knuckles look like tho.
