HQ 107 advice
I'm considering the big bore 107st kit from Head Quarters. They quoted me $2300 for the kit which would include:
boring your cyls
reworking your heads
pistons
cams
pushrods
tubes
He claimed I can get 120+ tq and 110+hp excellent numbers and well worth it if true anybody else getting these results with this kit, after a proper tuning in. Now the SE stage IV kit is about he same price with a little less impressive but acceptable numbers results on the Dyno graph.
http://www.harley-davidson.com/en_US..._SE10_Full.pdf
Looking for some advice, plus for those who did the HQ 107 is this all inclusive. will I have everything needed for this project.
As you can see I am no gear head, my buddy who has done a couple and will assist me (watch over my shoulder so I don't FU) all the way through. But I want to do the research and the purchase so when project is complete I just may be on leg to gear head status.
Just so you know I am looking for low to mid power I don't get the bike much over a 100 anymore but love the power off the line.
John
boring your cyls
pistons
cams
pushrods
tubes
John
I did a 95"ht pkg, they claim 90-100 hp & 95-105 tq, I made 96.43 hp and 100.47 tq, the key words are PROPER TUNING!!!!!
get on the hq q&a forum and ask Doug or Kevin, then follow their advise/recommendations TO THE LETTER, you will attain the claimed performance
the machine work/tolerances on the hq stuff will blow away the se crap... by a mile, that alone would be worth it to me, makes for a longer lasting build.
build it right, and you will do it only once.... don't penny pinch, if you spend an extra $800 or so now, you won't spend another 2-3k later... don't ask me how I know!
boring your cyls
pistons
cams
pushrods
tubes
John
boring your cyls
pistons
cams
pushrods
tubes
John
If you are going to fixate on peak dyno numbers, do something else. Peak numbers have little to do with rideability or the overall power of the engine since it's the area under the lines that represents the aggregate power of the engine. As for HD's stuff, it's mass-produced and the components are simply pulled from a shelf. Doug, the owner, does all of the machine work at HQ so you will get precision, individualized workmanship.
On the other hand, if you can find someone who has a properly assembled and tuned HQ ST 107 who is unhappy with the build, please report it because I've never seen one on HDF.
As for "anything else," a new pressure plate for the clutch should do it, along with HQ's black ops liftes. Nice thing about HQ is they aren't going to oversell you with roller rockers, larger throttle body, larger injectors, etc. that others push.
Good luck with your project.
$2300 is probably not too bad of a price. Does that include return shipping? Hard to say without knowing wether they are doing just a clean up of your heads, or something more extensive. Although Ive never used them, and have no reason to. Seems as though some here have had good luck with the HQ stuff.
As stated, at the bare minumum you will need to upgrade your clutch as well.
I have had three HQs builds 103 and two 107s---I thought the 103 was fast but it cannot compete with the 107 --- the 107 simply hauls azz -- no problem getting the front wheet in the air or getting bike sideways -- neither of which I condone )stunting on a HD at bike night is dangerous) I have no numbers becuase I have the pro tuner (I'm not convinced this is the best way to tune a bike) and bike has never been on a Dyno -- you will also need a AIM VPC-92 the 107 will eat up a SE clutch plate -- I have no doubt you will get 110/120 most likely you will get more -- but the numbers don't tell the story -- the bike is easy to ride I have 7,200 miles on this 107 no motor issues at all --- I have gone through a belt but that is different story
boring your cyls
pistons
cams
pushrods
tubes
John
boring your cyls
pistons
cams
pushrods
tubes
John
John
John
In addition to the lifters and clutch already mentioned, you will need the following off the top of my head:
Cylinder base o-ring
Oil return o-ring (under the cylinder)
Intake seals
Complete rocker box gasket kit
New rocker box breather filters
Exhaust gaskets
Oil pump o-rings (there are 3)
Inner cam bearings (Torrington B-168 iirc)
Cam cover gasket
Lifter block gaskets
Push rod tube o-rings (3 per tube iirc)
Oil
The HQ builds will deliver the numbers if properly assembled and tuned. My HQ 103ST numbers are in my sig. They start easy, run smooth, and have great rideability. You'll be happy I'm sure.
Zach
Edit to add: You will also need a couple of tools you may/may not have. You will need a ring compressor and an inner cam bearing remove/install tool. Also get yourself a tube of assembly lube. I bought a ring compressor from my local Napa store and it worked great. I did spring for the JIMS inner cam bearing install tool, but rented a puller from Auto Zone. Not the right tool, but I was careful and it worked.
Intake seals
Exhaust gaskets
Cam cover gasket
Oil
Zach
Good advice.
