fog lights for street glide
RE: fog lights for street glide
I have the HD Fog Lamps, used them instead of Spot Lamps because I like the naked fairing. I get good side to side beam spread from them, significantly better road illumination than the headlamp alone, and they're cheaper than the spots. Don't know that they'd be much use as true "fog" lamps, though. Halogen bulbs...seems like you're still going to white-out with them...
Anyroad, find them here: LAMPS
The kit comes with a handlebar mounted switch, which I found kinda lame, so I picked up the rocker switch for the spot lamps on an Ultra and rewired it. And while mine are powdercoated black, they're originally chrome.
I have the HD fog lamps on my 04 EG and they work great; get lots of attention from motorists and good wide illumination for me.
Cosmeticlly, spend the extra bucks, it won't exceed $100, to have the wires run inside the engine guard from the lamps to the center of the engine guard under the frame tube. It makes for a much neater installation; like running wires inside the handlebars.
ORIGINAL: SGMike
Hey, nice Street Glide! I plan on putting those same lights on my X, good to see them installed. I need extra light to spot bambi before he crosses my path ( upstate NY ). What kind of wind deflectors are those? They look adjustable. I have factory ones.
As to the wind deflectors, those are Freedom Wings, and they are adjustable. Push 'em all the way out for full deflection, or rotate them in and it'll blow a breeze across your face...great for the hot days. Find 'em HERE
And I second the internal wiring notion. The way the clamps on the lamps are set up, the wiring runs up into the engine guard and is covered completely by the clamp. Very clean.
(And, no, I haven't run my internal yet, I set the lamps up on my riding vacation and didn't want to take the time to drill the bar...but it's on the list)
ORIGINAL: Pat
I agree. I really like how you've gone to 'Black', slowly going the same way with my 'sloptail'.
If anybody's interested, you can see more pictures HERE.
Now back to your regularly scheduled topic...
