Oil Filter Failure
Oil Filter Failure
Anybody ever have a new oil filter fail to the point of loss of oil pressure ( 10 lbs @ 60 mph after running 20 miles). Had the oil and filter changed and the next day the pressure was almost lost. I shut down the bike and trailered it back to the dealership. They said I had a defective oil filter and replaced the oil and filter then ran it on the dyno to make sure the problem was fixed ( no charge for anything). I have 100% confidence in my dealership ( Wolverine HD, Mt Clemens, MI ) service dept. Just curious - how common is this?
i cant see the filter causing a lower pressure since the filter doesnt really create any pressure anyway. If it created all the pressure in the system the rest of the engine would be starving for oil until the bypass opened. Also, your oil pressure gauge alerts you of any internal engine problems and if the system pressure was created at the filter, prior to the engine, then you would never see any problems if they were to arise. I dont know what the problem was but I cant see a failed filter causing that.
Joe from So Cal
10-14-2018 07:06 AM
Ron750
07-18-2014 08:18 AM
roadking1327
Oil Archive (no new posts)
14
04-02-2007 05:30 PM
