Gas Tank Removal 07 Ultra
Am I the only person that thinks the manual is a little misleading. It goes into great detail about removing the console, fuel pump unit etc. My question: WHY? It's great that instructions for removing the console, fuel pump, etc. are made available but why would you do that just to remove the fuel tank??? I think the procedure outlined above by Chester pretty much says it all.
Am I missing something??
It finally dawned on me that step 4. on page 4-4 says "Remove console. See CONSOLE/CANOPY, REMOVAL, step 4." I do steps 4.a through 4.f on page 4-6 (meaning I do step 4 only) to remove the console and then go back to the tank removal section. All the other steps in the CONSOLE/CANOPY REMOVAL are for removing the CANOPY.
It's been a while but I think I remove the console to disconnect the tank overflow tube and vapor vent tube instead of pulling them up out of the frame when I'm walking away with the tank. Also, there's an electrical connector under there to disconnect.
I don't know it this makes sense but it was the only way I could figure why I was directed to remove the console section. I do know that installing the Herko quick disconnect on the crossover line makes complete tank removal a breeze!
If the bike has not been run for a day or more, I have bypassed those steps a couple of times without getting any spray when disconnecting the fuel line quick disconnect. Just have a rag under it to catch any minor leakage. I tried it after reading this tip on the this forum. Just saying, if your Ultra is winterized for storage, there is really no need to run the engine to purge the pressure.
OOPS! I didn't originally notice that your question was asked last AUGUST!
Last edited by Woodchuck; 01-29-2010 at 12:23 PM. Reason: Justify the stupid winterization remark
It's been a while but I think I remove the console to disconnect the tank overflow tube and vapor vent tube instead of pulling them up out of the frame when I'm walking away with the tank. Also, there's an electrical connector under there to disconnect.......
