anyone swap a 08 tank to a 07?
08-25-2009, 07:38 AM
I'm in the process of doing this. rerouted the wiring and so so close to fitting. has anyone done this mod? need help with this one.
08-25-2009, 06:30 PM
tank swap
time for a bump hoping someone else has done this, or am I the first???
08-25-2009, 07:01 PM
only problem i can see other than your wiring issue would bethe seat fitment the nose of the '07 seat might not line up with the '08 tank just one thing to think about
08-25-2009, 07:03 PM
tank
I'm swapping to the larger 6 gallon tank and 08 seat as well.
08-25-2009, 07:16 PM
You'll probably need to cut the weldment off the frame for the engine stabilizer that is under the tank. You'll then need to weld a weldment onto the front and drill and tap the head to accept the engine stabilizer up front.
08-26-2009, 06:09 PM
tank
Thanks dawg, your right. I read this and ran out to the shop and sure enough it was resting on isolator. Will mod a new one for sure. thanks again.
09-13-2009, 11:49 AM
decencyxdefied
02-23-2015 10:52 PM
TLONG
03-16-2014 09:10 AM
ultralongridesoreass
08-25-2009 07:19 PM
donf610
10-23-2008 07:38 AM
whetstone
05-23-2008 05:33 PM
