Wires Chaffing strikes again!!
Old 08-22-2009 | 04:35 PM
glide2005's Avatar
glide2005
Good post Steve, I had similar problem happen also. The wire that lites up your oil pressure light was chaffed, causeing the bike not to idel. Fixed that, then the two wires that connect to thottle cabel for the cruise control were rubbing on the gas tank and blowing the acc. fuse.
Old 08-22-2009 | 06:11 PM
rjmac53's Avatar
rjmac53
just went through the same thing last week. the right side blinker etc. hookup from the main wiring harness. Three of the four wires in connector were chaffed through...
Old 08-22-2009 | 06:58 PM
maineultraclassic's Avatar
maineultraclassic
It's a simple fix that should have been done at the factory, and it can leave you stranded on the road.......that's what pisses me off about it.
My buddy's bike is an '05 EGC, mine is a '05 EGUC.............but I'm sure it's not limited to just '05s since the wiring is the same on all touring bikes.
Steve
Old 08-22-2009 | 07:04 PM
harley0711's Avatar
harley0711
Originally Posted by jamesw
Issues like these aggravate the s**t out of me! I had the same type of issue with a wire bundle that came out and was secured with a Christmas tree clip to the bottom of the radio. I don't know if it was misrouted at the factory, or by the PO. I had to pull the terminals out of the connectors, re-insulate the wires with shrink tubing (two layers)reinstall the terminals and correctly route the harness. It had been run under a bracket with a 90 degree bend instead of on top, so it chafed thru.
I wish I had taken photos of it, so I could communicate the issue more clearly.
Glad you got yours resolved!
I am with you - great post here and SEVERAL others saying (it happend to me) still not one good (or bad) picture..
It would really help
Old 08-22-2009 | 09:17 PM
maineultraclassic
When we have my buddy's fairing off to replace the brackets, I'll take a picture of the location and the fix to correct it. Can't show you the chaffed wires, they are all sealed up and back to new again.
Steve
Xarmy2005
Audio Systems
02-25-2018 06:43 AM
AAWAV
Audio Systems
62
08-06-2015 02:33 PM
CM22
02-07-2013 01:39 PM
Mr. Mike
General Topics/Tech Tips
11-07-2011 08:48 PM
BadPiggy
02-17-2010 08:31 PM
Quick Reply: Wires Chaffing strikes again!!
