Tour pak Luggage rack
In addition to measuring and making sure before drilling holes, I suggest you use masking tape and make all of your marks on the tape. You can then re-measure and actually put the rack on the marks to make sure everything lines up properly. Drill the holes right through the tape, then remove the tape and install the rack. I've mounted a few this way for friends and have not had any problems
When you get the Template...THROW IT AWAY!!
Take some blue painters tape and cover well past teh areas you will be drilling. Set the rack in place, and measure to insure its centered. Stand back and LOOK at it from different angles to double check its looks. Adjust as needed, draw a mark around each of the 4 legs, remove rack, drill with the CORRRECT sized bit. Drill slowly so it doesn't walk on you. Remove tape, install rack makingsure to put some silicon on the inside of the tour pack around each bolt to seal out water. Thighten and your done.
Now have that beer
Now have that beer
