Tour pak Luggage rack
Well I like to do things myself but I seen that worthless HD template and there is nothing flat about the tourpak lots of angles. I looked up how much a new tourpak was. Went to my dealer and they said $50.00. So I went and had a beer and let them do it.
I wasn't tired one bit when they got done.
+1 on the tape. Put the tape on, set the rack on the tape, draw a circle around each leg, drill the correct hole for each leg, pull the tape, fasten, and open that beer.
Seriously took me less then a hour. If you are getting a rack setup for a light (AeroRack?) One hole is larger then the other three to make room for the wiring.
You like to do things yourself but paid the dealer $50 to drill four holes in plastic and put four screws in?? What kind of things do you do yourself??
Just curious.
