Oil Coolers on baggers
Old 06-05-2006 | 12:28 PM
matt's Avatar
matt
Default Oil Coolers on baggers
Okay, another Newby question. I did a search and I couldn't find anything on oil coolers, I know if you increase engine displacement it is factory recomended that you add an oil cooler and/or upgrade kits come with oil coolers, but what is the best oil cooler for the money when adding one on a stock bore? Thanks
Old 06-05-2006 | 12:59 PM
PhilM's Avatar
PhilM
Default RE: Oil Coolers on baggers
The HD one is good.
I have used Jagg (Deluxe version) on several bikes, including the one I am riding now.
Both are good and will give you ~30 degree reduction in oil temp.... good investment!
Old 06-05-2006 | 01:38 PM
100thRK's Avatar
100thRK
I have the HD Super Premium Oil Cooler Kit 62895-03A and it works well on my Road King. I do have a modified motor and the cooler drops temp about 20-30 degrees on the road. Helps slightly in traffic just due to out side the engine exposure but not much. Don't notice the cylinder head heat on my inner thighs as much with it. Expensive but remember 21% average at Zannoti's!!!
Old 06-05-2006 | 11:54 PM
Lpye's Avatar
Lpye
I use the HD SuperPremium oil cooler. Added the cover and it looks pretty good. Noticable difference in oil temp.
Old 06-06-2006 | 12:05 AM
mikeisglidn's Avatar
mikeisglidn
mine is a cop bike and came with one makes a big difference in traffic on a hot day.
Old 06-06-2006 | 12:39 AM
Slider's Avatar
Slider
The Jagg Cooler is an excellent choice, but if you want something a little different look at this one from Merch
[IMG]local://upfiles/7057/A8F0A1DA9F07444FA7CFB69B46DAD7AC.jpg[/IMG]
Old 06-06-2006 | 10:29 AM
100thRK's Avatar
100thRK
That is definately different!!!
ORIGINAL: Slider
Old 06-06-2006 | 11:59 AM
Bruce00's Avatar
Bruce00
ORIGINAL: 100thRK
Zanotti has it for $338.12
Old 06-06-2006 | 09:30 PM
Slider's Avatar
Slider
ORIGINAL: 100thRK
ORIGINAL: Slider
I forgot to mention, it also acts as a filter, with a bronze filter that can be cleaned and replaced. It also can be operated as a filter only in cold weather...just a quick turn of an allen wrench.
Old 06-06-2006 | 10:53 PM
Steele's Avatar
Steele
Is the HD Super Premium Oil Cooler Kit 62895-03A easy to install ???? Looks simple. Anyone installed their own ?????
Quick Reply: Oil Coolers on baggers
