Cutting into saddlebag
I have a Sony with a ipod cable into which comes out of the back of the radio. I ran the cable under the tank console and seat going into the bag. I was thinking of using a drill bit the size of the cable to lay the cable in as it goes into the bag. I didn't know if this would eventually cause a crack to run from where I drill it. Or any other problems. If anyone has a better solution that would be appreciated too.
A guy I ride with did the same thing and drilled into his bag. We did it about 2 years ago but what we did was drill the hole a little bigger than we needed and the installed a rubber grommet that we picked up at a regular parts store for about $2. No problems so far and I would guess hes put on at least 10K. No cracks or problems. Good luck
On a similar note I drilled into my right bag two years ago to relocate the air tank for my seat inside. I drilled two holes on the inside for screws to mount the tank in the front inside wall area of the bag then another above to run the air line inside. Two years and about 17,000 miles and it's still going strong, lookin good as well.
In God we Trust
dd
BlackPearl#1
Audio Systems
05-27-2015 07:11 PM
