gas tank
Old 08-18-2009 | 04:05 PM
dusty rider's Avatar
dusty rider
Default gas tank
We're talkin' FLHTC....will an '08 gas tank, fit an '07 bike, with no further changes (seat, console, fuel sender, etc.)?
Old 08-18-2009 | 04:19 PM
JPstreetglide's Avatar
JPstreetglide
I know the seat wont fit. Dont know about the internals or the console
Old 08-18-2009 | 04:43 PM
Roadhound's Avatar
Roadhound
3rd Gear
The tank will not fit anything but an 08 or up. When they increased the capacity, they made the tank longer and deeper. They had to relocate the upper engine mount from underneath the fuel tank, between the cylinders, to the front cylinder head for clearance of the fuel tank. Hope this helps.
Old 11-23-2011 | 02:50 PM
Ultra89Rider's Avatar
Ultra89Rider
I just posted this on another thread about this subject.
Originally Posted by Ultra89Rider
When the 6 gallon tank can out on the 2008, there were many questions about if they can be mounted on earlier frames?
It can be done but with many part changes and welding on the frame. To change the mounting locations for the motor will require removing the motor to cut the old locations and weld the new one in place.
The motor mounting locations were changed along with the location for the coil and a new seat.
The Fuel Tank and seat points mounting points were moved. The seat was changed to make room for the new tank. The seat does not have the same mounting locations. They are not even close.
The 6 gallon tank has made the '08 frame a "One Year" frame.
Old 11-23-2011 | 05:24 PM
HD Jim's Avatar
HD Jim
I ordered this for my '07 SG for January install : 6 gal tank
http://justgastanks.com/p1747/Paul-Y...duct_info.html
'08 tanks will not fit earlier year HD
Old 11-24-2011 | 03:32 AM
grbrown's Avatar
grbrown
We've got three threads all asking the same question at present! Search them out to get the full range of replies.
The Dane
07-07-2012 11:19 AM
sportyguy69
10-18-2011 03:07 PM
chrislind2
04-01-2011 08:40 AM
nightvision20/20
General Topics/Tech Tips
03-06-2010 01:46 AM
buffettphan
02-16-2010 10:55 PM
Quick Reply: gas tank
