Clutch adjustment
Old 08-17-2009 | 07:15 PM
FLoTR's Avatar
FLoTR
Default Clutch adjustment
Reading the manual, it says 1/2 to 1 turn after screw touchs, then lock it with the nut. What kinda tool are you people using to TORQUE the jamb nut? I thought of tightening it as tight as possible with a wrench, mark the allen bolt and finish it off with a torque wrench, provided I don't exceed 1 full turn of the allen bolt. Will that work ok?
Old 08-17-2009 | 07:19 PM
cuda67bnl's Avatar
cuda67bnl
I don't torque the jam nut. I just snug it with a wrench.
Old 08-17-2009 | 08:37 PM
SPARKY01's Avatar
SPARKY01
Thumbs up clutch
+1 on the snug. use claw foot wrench.
Old 08-17-2009 | 08:56 PM
nocarb's Avatar
nocarb
Just hold screw with allen wrench while tightening jam nut.
Old 08-17-2009 | 10:21 PM
oinker02's Avatar
oinker02
Yep, it only has to be snug, not TIGHT. There might be a torque value in the manual, but ignore it and simply go for a good snug twist that locks the allen screw setting from vibrating loose.
The critical adjustment is the allen screw, not the locking nut torque.
The allen screw sets freeplay in the release mechanism-that is the actual clutch adjustment...There needs to be enuff freeplay that the clutch is allowed to fully clamp/engage when lever is released, and fully disengages when lever is squeezed against bar......(A cold engine when started in gear with clutch squeezed WILL cause bike to lurch due to fluid friction on the clutch plates, not because clutch is misadjusted)
From there adjust cable outer cover length to get proper lever freeplay. All the cable adjustment does is adjust length of outer cable covering, it does not adjust release/throwout bearing of actual clutch.
Old 08-18-2009 | 06:09 PM
FLoTR's Avatar
FLoTR
Thanks Oinker2. I adjusted the freeplay in the cable this past Saturday to around .090(I'm **** like that). Today I pulled it to check it and it's got to be over .125 and the jam-nut is still tight. What gives Could the cable be stretching? It's got about 5300 miles on it.
Old 08-18-2009 | 06:14 PM
Gordon65's Avatar
Gordon65
here's a video of a guy doing the procedure.....
http://www.hdtalking.com/transmissio...ent_video.html
scroll down a bit to the vid.
Old 08-18-2009 | 06:29 PM
Notgrownup's Avatar
Notgrownup
Damn...that was easy!!!
Old 08-18-2009 | 06:35 PM
FLoTR's Avatar
FLoTR
simple enough. Thanks ya'll
Old 08-18-2009 | 06:39 PM
Gordon65's Avatar
Gordon65
just don't drop the cover like him...hahahahha
Quick Reply: Clutch adjustment
