Finally got the visor's on...What a BITCH!!
Dude I feel your pain, I jacked with mine endlessly before finally being satisfied with it. I didnt leave the original ring "real loose", just backed it off about a full turn. I know its frustrating but just keep fooling with it, you'll find the right combination.
I had a 1/4 inch gap on mine after several attempts to remove it. What I did is: every time I washed the bike I tightened it some. Then finally it closed the gap. I did not have to force it at all. The screw would be slightly lose as where it would tightened a little at a time.
Since then I have had to remove it for painting reasons and it went on easy and no gap.
In God we Trust
dd
In God we Trust
dd
I hear ya dude. I was so mad to find out that sometimes they just fit that way. That wasn't an answer I was happy to hear. The gap looks like crap. I know this option sounds crazy but it works and looks GREAT. I plan on keeping the visor so I didn't mind "modifying" the flange.
I tried to search again for the thread I found. It was from about 3 years ago. The guy put pictures up where you can remove the OEM ring. Then you bend the outer flange with pliers. Make a bend at the top, sides and bottom to start with. That gives the new cover something to hold on to. Last, tighten the screw and you will love it. Not only that you won't mind removing it you need to. My thought was "I am going to need to remove this for something (who knows what)".
I would need to see pics of that, Are any of you guys putting any kind of wrench to the nut on there? That is part of the problem, I get it to the point that it is so tight, the nut spins too. I wish they would just make one that replaces the stock ring. Don't the ones for the driving lights replace the stock rings?
Looks very cool. I like those rings so much I was determined they were going on mine also.
This is funny. I just went through the same darn project 2 days ago. I ended up finding a thread on here that said to remove the original and make small bends in the outer headlight flange. It was great advice as it went on very easy. Easy enough that I removed it just to show show someone how I did it. Could have been much better designed.
I didn't get the ones for the rear blinkers.....good idea!
I don't guess you have any pics of this do you? I know, I know.....it sounds easy, but believe me if it can be fu^&ed up, I can f*&k it up....
