Biketronics Sony radio Beeps and CD Skips often, any help with this???????????
It beeps when you're driving if you have the 'beep' activated, because the AVC, (automatic volume control) adjusts with your speed. Turn the beep OFF and that will stop. It will always beep 3 times when you turn the bike off - warning you to remove the face-plate. Make sure the unit itself is attached securely - if it's loose and bouncing around, the CD's will skip.
riteway
05-10-2008 08:55 AM
