Swing arm bushings ?
Old 08-17-2009 | 09:10 AM
Yachtman's Avatar
Yachtman
Dawg,
Why are you thinking of going to a Glide Pro?
Yachtman
Old 08-17-2009 | 03:40 PM
dawg's Avatar
dawg
Originally Posted by Yachtman
Dawg,
Yachtman
When my motor mount goes, I'm going to put in a Glide Pro to try it out. I've heard lots of good feedback
Old 09-12-2010 | 08:01 PM
MxNut's Avatar
MxNut
Default wobble
I have a 2007 FLTR 25000 miles , it just does not feel as tight as before. I had the steering bearing tension tightened up to specs by the dealer. I still feel the bike is '' unsteady or wobbly''. I have a frame stabilizer. Would changing the bushings in the swigarm make a big difference? Or does something more intense need to be done as far as changing parts. Is there a part that would bolt the front of the engine to the frame, illiminateing movement and making the engine part of the frame.
Thanks.
Old 09-19-2010 | 11:42 PM
dhutchison's Avatar
dhutchison
If you were to make "the engine part of the frame" then it'd be just like riding an old EVO softail or anything else non rubber mounted. I'm sure it would certainly firm things up so to speak but the overall ride quality would suffer greatly.
Old 09-20-2010 | 08:46 AM
grbrown's Avatar
grbrown
MxNut,
The swingarm bushings since 2002 and including your 07 have steel self-aligning bearings, which should be OK. Earlier bikes had a 'cleve block' composite bushing that had a degree of 'give' in them when new and could collapse eventually, so they can have more serious handling problems than your bike is ever likely to suffer from.
The bushings mentioned in this thread may have a benefit to you, but before considering changing anything I suggest you check the bike over. Tyre wear and pressures can have a serious affect on handling, also vehicle and wheel alignment.
There are ways of improving your bike with bolt-on goodies, but there are also things that can easily be adjusted to make it handle better.
harley#1
09-04-2018 08:25 PM
foxtrapper
01-13-2014 07:12 PM
lenny
08-30-2011 11:32 AM
clove07
Shovelhead
08-17-2009 11:05 PM
gobby
Harley Davidson Videos
03-29-2006 01:18 AM
Quick Reply: Swing arm bushings ?
