Change MM TB
Change MM TB
Can anyone tell me if the MM EFI is a CAN Bus. I am doing some playing with a 04 TB. (I know that is a Delphi) But other than the idle stepper motor working opposite and the TPS having to be recalibrated why can’t a Delphi work electronically? I know fuel pressure will have to be raised. That can be done easily. The TPS is just a Hall Effect sensor. They use the same MAT. The MAP is outside of the manifold on the MM so that is not an issue. If this is a CAN system, then idle stepper motor operates on a square wave and should be able to be adjusted. If anyone has tried this please let me know what issues you had. Maybe I am being too simplistic but I fail to see why it will not work. The Power Commander would most likely need a custom map. If anyone has any info, even if you think I fell on my head, let me know.
Lucky, no you can't. You'd have to change your ECU. I ran a MM system for several years with an S&S VFI ECU. S&S has a mod where you relocated the MAP sensor to the intake manifold so the system mimmicks Delphi. Works like a champ. If you go this way, I'd spend the extra $200 bucks and add Closed Loop 02 sensors. That should solve your problem.
I may be wrong, but I believe the ECM "looks" for the matching TB, hence a Delphi TB won't work with an M&M ECM. The Thundermax dilemma is that when converting over from M&M you need to use a Zippers TB. At least that is what Zippers told me when I bought their kit a few years back. You may be able to use a HP Inc. TB, but I don't know or sure. On my '01 I went with the Zippers ECM and TB with auto tune. Now on the later Delphi bikes you can swap out the HD Delphi ECM for a T-Max ECM and keep the HD OEM TB. But like I said, I could be wrong.
Mark
