2010 Heat Issue??
Old 08-14-2009 | 05:25 PM
papa_freeman's Avatar
papa_freeman
Default 2010 Heat Issue??
Not sure if this has been discussed... but guys/gals with 2010 models--- I understand the new pipes are running MUCH hotter than prior years--
How noticeable is it? has anyone upgraded to stage I or II on a 2010?
Old 08-14-2009 | 07:12 PM
RodFarmer's Avatar
RodFarmer
I just got a 2010 Limited. This is my first Harley, so I have nothing to compare it with. It throws less heat on me than my Valkrie, but more than my Goldwing. I was expecting more heat than what I get. I do try to stay away from sitting at red lights. I live in Phoenix, so heat is an issue for me. I't doesn't take much for the back cyclinder to kick off when it is over 100 degress outside. I haven't figured out if it really helps or not.
Old 08-14-2009 | 07:14 PM
RodFarmer's Avatar
RodFarmer
I forgot. My Limited has an HD Stage 1 from the dealer, SE pipes, AC, and HD flash.
Old 08-14-2009 | 08:30 PM
Audioi's Avatar
Audioi
The hot ones were the previous versions. The 09 & 2010 are a little cooler thanks to the exhaust and the cylinder de-activation.
Make sure you have it turned on to take advantage of hot stop lights.
Old 08-14-2009 | 08:41 PM
twodollarbill's Avatar
twodollarbill
It has been discussed here before.
My '09 RG throws more heat off the right side than any of my previous HD's.
It's HOT.....DAM HOT!!!!!!
Old 08-14-2009 | 08:51 PM
tibadoe's Avatar
tibadoe
Hate to say it but the 09's are hot. Thanks to the EPA for requiring them to run lean. It does help some that the pipes were re-routed for the 09's. Can't speak for the 10's tho.
Old 08-14-2009 | 09:28 PM
papa_freeman
I think the 20's may be even hotter with the catalyst installed---
Old 08-14-2009 | 10:29 PM
Dbarrett's Avatar
Dbarrett
Stage III
Default Hot
Just bought a 2010 Ultra Classic and yes the right side does get quite hot, even for the passenger. My upper right leg gets pretty uncomfortable at stops. It is not a problem while in motion though.
Old 08-14-2009 | 11:29 PM
GMONEY220's Avatar
GMONEY220
Default Hot
09 FLHT,its still effen hot..not as much as my 06 but the wifey's right foot gets pretty damn hot.Plus this vegas heat aint helpn one bit!!!!
Old 08-14-2009 | 11:52 PM
Twinrider's Avatar
Twinrider
Same thing happened with my '09 commuting on hot days through stop and go city traffic. A custom-mapped PCV and stage 1 air cleaner from Fuel Moto totally solved that problem. Now the motor never gets hot enough for the rear cylinder to shut down. www.fuelmotousa.com
h-d wrencher
General Topics/Tech Tips
03-25-2018 10:32 AM
rvtlimited
09-13-2011 09:31 PM
PDDGM
01-20-2011 11:45 AM
coupe55
07-08-2010 10:53 AM
chipofsc
07-02-2010 02:23 AM
