I have an 09 EGS with the nice Brembos. It is tight. Any tricks on airing and checking pressures on the tires. The fronts a little easy, the rear is a pain in the butt.
...Any tricks on airing and checking pressures on the tires.
I've found the Accu-Gage EZ-Air model EZ02 very helpful. One end clips to the valve stem and the other is attached to the air hose. This gauge has a flexible hose and quick air release for overfill. Get the 100 lb version.
Works for me...
Yep, got one of these from Whitehorse. Works like a charm.
Another option is next time you get a tire change have a 45 degree valve stem installed. You can get them right from Drag Specialties and they make it easier to check.
