Fast Idle
Fast Idle
For the fifth time now, while on a vacation trip to boot, my 08 Ultra started the fast idle routine up to 2,000 RPM. I reset using the on-off four times but it happened again. They've reflashed this thing three different times. I've never had a bike with this weird problem in 30 years of riding. Can't they fix this once and for all!
Are you saying when the bikes turned off?? If so, I don't believe that would affect the idle..If it's done while the engine is running, yes it would affect the idle at the next start up.
through the years i've seen so many people drive up to a store or wherever they're gonna be parked, and rev the motor in their, for example, 64 chevy truck right before they shut it off. why? because they don't know any better is why. the fresh shot of gas washes the oils from the cylinder walls. i've also seen bike riders do the same thing. it's a bad habit to get into. every time when you shut off your motor, if you take a second and allow it to come to idle, not touching the throttle, you should not have the problem with hi idle. hope you get it figured out.
When you go to shut off the bike. Use the ignition switch on the fairing.
First let it idle for a few seconds. With you hand OFF the throttle.
Then use the switch.
Never had a problem with mine.
Do this, or deal with the issues.
And dont tell me other year bikes didnt have an issue. I have links saved for people who say that.
Lambda
24
05-22-2021 09:18 AM
