ignition switch crackling noise
04 Electra Glide.
When I turn my ignition to on, I get a crackling noise thru my speakers, whether the radio is on or off. If you are fimiliar with this, the sound is the same as when you would hook up your stereo speakers and hear the crackling. Any thoughts?
Not sure were the ground for the amp is but I found all the grounds in front of battery and all were intact. After checking many connections I found loose ground between frame and fork and that made no difference. Just happened to apply the brake and the noise changed swapped starter relay with the brake relay and noise went away. There is also a problem with the way this bike runs and will test that tomorrow when we get battery charged back up.
jmbaker3
08-12-2009 07:31 AM
