Has anyone added this to their RK? I am thinking about adding it to my RK Custom. If you have, what are your thoughts on the install and the end results? Thanks
Reason: .
UltraK, That does look sweet. I notice you also have the red lenses on your turn signals. My RK Custom has the same turn signal bar with the orange 'turn signal only' lights. Did you convert those to running/turn signal lights? If so, what kit did you use and where did you get it?
Thanks
etstrine,
I used the Harley run/brake/turn signal kit that plugs in under the seat. 5 second job and worth it, BUT I also wired my tri-bar lights on the chrome extender to work as run/brake lights too. I have since changed those RED lenses to smoked with red bulbs for brake lights.
