heat management ?
heat management ?
on tuesday we finally got up in the 80's,i'm driving home rush hour.i hit traffic now not that bad side road with lights and 2 lanes going into one.maybe a mile or 2.the bike started to idle lower than normal and eventually stalled 3 times would've been 5 times but i caught it in time.i already have the 25 degree inj. so i go to the dealer i bought this bike from.the service writer talked to a tech and he told me that's how the heat mangement system works,i'm like it wasn't that hot and that much traffic and it's may.what i'm i going to do in july august? something has to be adjusted?maybe you can bump up the temp in the map?i sat in traffic over an hour with my 04 injected heritage and never had anything like this happen.i'm starting to wonder if it was a good move to trade in the heritage for this!
RE: heat mangement ?
Jersey,
I was up in NH last weekend and it was friggin hot.... 86°F. On our way home we was held in traffic for a bit and the longer we sat there/barely move, I noticed the bike starting to idle down.... then eventually going into the miss fire mode. This i did notice as it idles a little rough. The only stall I had was when I went to take off the last time.... I believe that was operator error....... Other than that I had no stalling.... and Ill tell you my thighs (cough cough) where hot.....
I was having that problem before I had the 1K service done. I told the dealer about it and since they made the adjustments it has not happened again. I was even in some traffic this weekend, and with the temp close to 90 the bike still idled fine. I do not have a fuel management device on my SG and I am running the stock tune with the 8 degree injectors. I'll ask the tech for more detail about what they did next time I am at the dealer.
ORIGINAL: SpikeCT
Dealer I took my bike to with the same problem you have said and I quote "If you have any mods.. exhaust, intake...ect. done on an 06 it will run hot, it's too lean straight from the factory." Had him put the SERT on and dyno it, ran in 94 deg. heat this weekend and got in stop and go traffic on the interstate. Bike got hot but did not go into heat management like before. Your going to have to do some kind of fuel management on the bike.
Yoman
Yoman
ORIGINAL: Bruce00
I experienced my first time in the heat managment mode in lower Manhatten sunday. Bike idled like crap but never stalled. But I did keep the revs up a tad when letting out the clutch
