frikkin exhaust gaskets
Old 08-10-2009, 10:43 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
Default frikkin exhaust gaskets
My big radius will be here tomorrow, so I dropped the slipons and factory headpipes today. I cannot get the exhaust gaskets out.....any tricks or tips?
Old 08-10-2009, 11:20 PM
King Crimson's Avatar
King Crimson
King Crimson is offline
Use a long pik like a dentist tool.
Old 08-10-2009, 11:21 PM
OhioSkully's Avatar
OhioSkully
OhioSkully is offline
Ya what King said does the trick
Old 08-10-2009, 11:25 PM
emwolb's Avatar
emwolb
emwolb is offline
if you have a paint can opener they work well too. or even a seal remover.
Old 08-11-2009, 01:26 AM
OG1's Avatar
OG1
OG1 is offline
if you are having trouble getting the old ones out, just wait til you try and put new ones in. the standard HD ones are a real treat to install.
Old 08-11-2009, 02:55 AM
Smyln's Avatar
Smyln
Smyln is offline
I see you are replacing your exhaust gaskets.
Did your big radius pipes come with new gaskets
My pipes MAY be here tomorrow or the next day depending if the shipping company got the address correct...UGH...
Be interested to see how your install goes, cause I'm right behind you
Old 08-11-2009, 05:20 AM
brettnbama's Avatar
brettnbama
I was told they didn't come with the vance and hines, but even if they did, the HD gaskets were better, and I wasn't told that by an HD employee. I haven't gotten the pipes yet, but I should be installing them today. Your dealership should have the gaskets in stock and they aren't expensive. I think it came to $13 and some change for both......also, during my research on removing and installing the gaskets, I found out something that I wouldn't have just known. The regular HD gaskets are slightly tapered, the thinner end of the taper should be facing the pipes when you install them into the head...
Old 08-11-2009, 05:26 AM
ac72rat's Avatar
ac72rat
ac72rat is offline
Default exhaust gaskets
forget the conical gaskets and get the screamin eagle gaskets
Old 08-11-2009, 06:05 AM
Road Ranger's Avatar
Road Ranger
Road Ranger is offline
What he said...^...The SE gaskets are much better.
Old 08-11-2009, 08:40 AM
genedjr's Avatar
genedjr
genedjr is offline
The stock gaskets are very good and as noted cheap. A awl or relitively sharp screwdriver can easily pry out the old gasket. Just make sure the gasket material is completely out of the exhaust port and the header pipe flange is smooth and clean.
...gene
Quick Reply: frikkin exhaust gaskets
