Need Help With A Turn Signal Problem
I was coming home from Sturgis today and my bike started doing something odd. When you turn the ignition to "on", the left turn signal would start to flash. It would not turn off by using the turn signal switch, you would have to turn on the right turn signal, which would make them go to hazard, then hit the right turn signal switch to get them both to shut off. Also, while riding, I would look down and every so often and that left turn signal would be flashing, so I would have to turn on the right so both would be on the hazard mode to get them to shut off. I was told that there is a turn signal module that may be the problem, it costs $114.00 from the moco and I hate to buy it if it's not the problem. Anyone else experience this? We rode through a lot of rain on this trip so I don't know if that may have something to do with it. I gotta believe these are made to work in rainy conditions. Anyway, it worked fine for the last 200+ miles.
Thanks,
Joechief
Thanks,
Joechief
Thanks,
Joechief
Thanks,
Joechief
Joechief
agreif
09-04-2019 09:43 AM
