I'm not happy with my audio
Old 08-11-2009 | 10:19 PM
Wassup8687's Avatar
Wassup8687
Firecap is the one who can hook you up. He really knows his stuff.
Old 08-11-2009 | 10:25 PM
Ben R.'s Avatar
Ben R.
While I am happy with my speakers the OL says she has a hard time hearing hers. All of these amp kits and speaker upgrades I have been finding are for two speakers, does anyone make anything to upgrade a four speaker system?
Old 08-11-2009 | 11:22 PM
08roadglidejoe's Avatar
08roadglidejoe
Call Biketronics
Tel. (800) 735-2419 and they can hook up up. They have both 2 channel and 4 channel amps. They will listen to what you want and get you what you need.
Old 08-11-2009 | 11:44 PM
motocop's Avatar
motocop
Default 4 speakers 2 channel amp
Again Firecap has the goods. 125.2 Arc Audio Mini 2-channel amp with 6.5 inch Arc Audio speakers with adapter rings to fit the 5.25 inch hole in the fairing. 5.25 inch Arc Audio speakers in Hogtunes adapters for the the glove boxes in the fairing lowers. All four speakers connected in parallel (2 per channel). If you want you can add the Hogtunes tweater pod also. This is the set up I am running under the advice of Firecap and I couldnt be happier. It is Very loud and Very clear even at 80+ mph with Rineharts.
Old 08-12-2009 | 06:32 AM
Garemlin's Avatar
Garemlin
Do any of these set-ups actually help with bass response??? Well I guess I should say mid bass response. I know you can only get so much out of a 5.25, but the stock speakers have none. I installed a pair of Infinity 5.25 Reference Series on my 08 when I had it. The sound was a little less harsh but it still had no bass response. Never really had much of an interest in upgraded audio (on the bike anyway) and never thought you could get good sound until I heard a Street Glide In G-burg during Bike Week. Sounded good for what it was and what it was on.
Oh and why do people feel the need to go to a 6.5 in the fairing. The frequency response (how low they go) on a 6.5 is only a little lower than a 5.25. I can't see in a fairing set-up how maybe 15hz lower would really make that much of a difference. And the sensitivity (loudness based on wattage input) is maybe a dB or two higher.
Old 08-12-2009 | 06:36 AM
ranman469's Avatar
ranman469
i had the 5.25 and switched out with the 6.5 components , the diff is noticeable . not as in real bass like in a car but in full bodied sound
i have a set of arc 5.25 coax for sale if anyone wants?
Old 08-12-2009 | 07:56 AM
1flhtk4me's Avatar
1flhtk4me
Not happy with mine either.The display took a **** yesterday!
Now is a dealer going to cover the warranty with extra speakers and amp????
Old 08-12-2009 | 08:19 AM
Trock's Avatar
Trock
The only way to get the full effect of the speaker and amp up grade is to change the stock radio. I put Firecaps ARC amp and 6.5 speakers on My Street Glide and the system came alive with the radio change. The OE radio is junk in my opinion and if you need to turn it all the way up the sound will be distorted. Firecap is the best I've dealt with in a long time. Also you can use a USB flash drive on the aftermarket radio. 4000 songs, an it plugs right in the front of the radio and the handle bar controls work it just like an Ipod.
Old 08-12-2009 | 08:34 AM
Skulmn's Avatar
Skulmn
I went with some real power..Sacrificed a bit of the trunk but I built a rack (not shown) to cover the amp and recover some space....
Old 08-12-2009 | 09:17 PM
KDUBYA's Avatar
KDUBYA
Originally Posted by bikergeoff
Not as clean looking as the speaker kits designed for the lowers, but they sound great. They are powered by a Hogtunes amp. Speakers are 6.5 JBL marine grade.
what do you have for speakers in the upper fairing?
