01 Road Glide Fairing lowers fit 05 Road Glide?
I found a nice set of 01 lowers off of a screaming eagle Road Glide for a couple of bills but the harley manual list a different part # for the 04 up Road Glides, is there that much diff or will they fit or no chance? Thanks for any input/
Gilbo
Gilbo
RE: 01 Road Glide lowers fit 05 Road Glide?
If there are two different part numbers, than rest assured there is a difference between the two lower fairings........and as I recall, the big change in the FLTRI for 2004 was the angle of the upper fairing and windshield, which would change the height of the lower fairing. So, that being the premise, the 2001 lowers won't fit the 2005 properly without some kind of modification.
Slider, was hoping that they would work on mine but a little to much just to take a chance on. I talked with him and they have all the mounting hardware. They are on ebay, do a search for item # 4643952128 they are v.black hope this helps you out.
Gilbo
Gilbo
BigDaveOnBass
11-12-2008 07:36 AM
