6.5 speakers
I'm using Polk MM-651 6.5", 2.7Ω coaxials, marine-grade. Since they aren't 4Ω like most replacement speakers, I can get a way without an amp. Plenty of volume without distortion even at highway speed.
I should also add that if you're keeping the rear speakers on a UC like I did, the rear 2Ω pair will be louder than the front, but a slight adjustment with the fader will even things out nicely.
Without an amp install a lot of speakers will make you happy. You can use 4 ohm speakers if it is a 06 or newer. you can go up on ohms but not down in ohms.
Before my am install I have tried several different speakers which were:
Memphis over size
Alpine spr's
Titan
All were good with out an amp, ones I added the biketronics 180 watt amp I stuck with the titan speakers
you must remember you will lose some volume with the 4 ohm speakers but have more usable volume with a much better clarity in sound. The closer you get to 2 ohm speakers the better volume. The titans which are 3 ohm had better volume than the alpines but the memphis had better volume than the titans.
In God We Trust
dd
Memphis over size
Alpine spr's
Titan
In God We Trust
dd
I will probably upgrade to a nicer set of components later, but for now this setup is a major improvement over stock.
