HQ 107 package
Toatl $ 3014.55
Shipping ?
Refundable core charge (700)
SE Cam Install Kit $100
Labor $780
SEST $400
Dyno $300
Net Total $ 3894
Think this is a fair price.
Going with the SEST because more tuners available around the Country and proven technology. Not knocking any others.
HEAD WORK
1) HQK-L-TC/EV-S3 (all cylinder head labor, porting, radiused valve job, chamber blend &
556.25
decking)
1) HQK-P-TC/EV-S3 (all new parts in cylinder heads, valves, guides,seals,spring
431.19
1) HQ-7000-E glassbead carbon out of heads
37.50
1) HQ-7008-B Machine 2 decompression holes
125.00
1) HQ-3600 Decompression valves (2) AKA compression releases
42.87
2) HQ-4530 Gaskets, head, .030" MLS type
40.86
1) HQ-HEAD-BOARD Fin Protector (heads bolted to this for shipping)
CYLINDER WORK
1) HQ-7100-K Bore (your) cylinders to 3.938"
220.00
1) HQ-7102-C Glassbead carbon off tops of cylinders
5.00
1) HQ-CYL-BOARD Fin Protector (cylinders bolted to this for shipping)
1) HQ-8-5200 Pistons, forged
391.40
RECOMMENDED PARTS
4) HQ-4225 Hydraulic lifters, Black Ops type
39.87 x 4 = 159.48
1) 17033-99 James rocker cover gasket and seal set
Cam Choices as per drive type and appropriate year
1) HQ-TC-575-HC Cam, chain drive, ‘06 Dyna and 2007-up all other models
279.89
Shipping ?
Labor $780
SEST $400
Dyno $300
Net Total $ 3894
HEAD WORK
556.25
decking)
431.19
37.50
125.00
42.87
40.86
CYLINDER WORK
220.00
5.00
391.40
RECOMMENDED PARTS
39.87 x 4 = 159.48
279.89
Anyone that can tune a SEST can tune a TTS, and YOU can also tune a TTS...not so with a SEST...
Just something to consider
Dont see adjustable pushrods, tubes, o rings for top end on the list. you can get the cam chest o rings and gasket seperately without spending the $100 on the SE install kit, should save you $80.00+ (ill only charge you $40.00 for that)
Seems like an ok price w/labor and dyno included.
As timvan stated you will need adjustable pushrods.
Yes have a set of HQ adjustables from last bike cam change
You keeping the stock TB? Having it opened up any?
Same TB, told not necessary for a bigger one.
Gonna run the stock clutch?
Dam I knew I was forgetting something
Does the price include all fluids?
No, will bring my won lubes.
Will the wrench stand behind his work?
Thanks for the heads up.
