Misplaced Instructions for Soos Extensions, pls help
Just do it! You will figure it out. Use the single type allen wrench. I can't remember the size but I remember the 3/8 drive socket type will not work. Pay attention to which hole that the stock hardware is mounted on the frame. If you move to the bottom hole you will scape more often when leaning into the twisties. Just install the longer bolts and spacers.
This is a very easy installation and huge on comfort.
You really shouldn't need the destructions...They're pretty easy to install...On the right side foot board loosen both bolts a bit and then remove one and install the extension, replace the bolt you took out with the supplied one that came with the kit, then remove the other bolt and install that extension and install the other bolt that came with the kit and tighten down.
On the left side foot board it will be the same for the front bolt but, on the rear there are two smaller bolts by the jiffy stand one bolt is accessed from the back side and one from the front side...it's easier to do if you have a lift but it can be done w/o one...pretty easy when you get into it...hope this helps.
LOL, just an email or phone call away. I hope you got squared away.
Jonny Cannon
05-02-2009 06:34 AM
