My 08 FLHX 103 Build
So I pulled the trigger on a 103 build and am happy, but not ecstatic. The bike drives great and has a very wide and fat torque curve, but I was expecting just a bit more than the final result delivered. I am blaming it on the thin CO air. Here are the details.
10 Litre Stage-2 Heads See: http://10litre.com/id47.html
SE 1550 Stroker Pistons (10.5 forged)
SE 253 Cam
Already had the Race Tuner and Bub-7 Duals. Bike sounds great and pulls hard from 2k RPM but is a bit weak off the line. It will loosen up a bit I am sure. Here is the dyno chart.
JKH
SE 253 Cam
JKH
and peak #'s dont mean squat unless your barstool racing.
see lots of guys that make good #'s, for about 500rpms. Then the motor falls flat on its face. Instead of bragging about #'s why dont you guys post some sheets....
Bruiser,
Those are not really bad #'s. Thats about right for the build you have there. The HD103 kits with 255's and stock heads are lower than that, but work well. The HQ103 kits I have built are 100-105hp with 110-115tq using a 10:1 CR. the 10.5:1 kits are more. It's all in the correct combination of heads/cams/and C.R. that makes a nice motor. It's hard to find parts that compliment each other and work well together, that's why its good to have a "package" deal from a reputable builder or company.......they have done the ground work for you and have combo's to prove it.
Kenny
Kenny
