Ok. here it is. I have a Aquatic av radio. 200 Watts of power ( 50 Watts x 4 Channels ). my speakers are Boston. 6 1/2 " RMS Power Handling - 50 Watts. Peak Power Handling -160 Watts. Looking for a 2 channel amp that will get the job done. I at least want to enjoy listening to it at 70 - 75 mph. Any Ideas on what I need ? At a good $$$.
where is the amp going, in the fairing I would go with a ARC , in the bags I would go Alpine amp. not much room in the fairing, I run the ARC amp in mine, works great.
I have a 2 channel Hawg Wired model that puts out 75WX2. Small, built like a tank and some of the best customer service I have ever encountered! Fits just fine under the stock bat wing on top of the radio unit.
I have a Dragonfly fairing. thats where I plan on putting it. No room in bags.
I ran a Arc mini in a Dragonfly I use to have. Your going to need a area to mount a external amp on first off. I made a shelf out of plexiglass and mounted the amp under the headunit. Also I mounted a garage door opener on shelf too. Shelf had added benefit of closing up bottom of fairing. I have some album pics posted on the forum. Is this a older Dragonfly to have 6.5" speakers? I had 6x9's in mine.
Does anyone make an amp that will fit inside the batwing but still work if I have the CB module? The CB sits on top of the HK, so any amp would have to be small. I may have to go with the HD amp that mounts under the tourpack.
The ARC 125.2 mini fits inside the batwing and you will retain all stock functions. I have a group buy going on right now. You can call me with any questions if you would like. My number is in my sig.
