Handle Bars
Old 08-06-2009 | 11:03 AM
Bertk's Avatar
Bertk
Originally Posted by ULTRA ZOOM
Yes I have ABS brakes
I am not sure if the ABS brake line has to be extended, so I PM'ed another member who installed the Sweepers on ABS bike. Will let you know what his reply is when I hear from him.
Old 08-06-2009 | 11:07 AM
klemay's Avatar
klemay
Im definilty going this route...my HD guy quoted me 500 for parts, 500 for labor...sheesh what a biz....
Old 08-06-2009 | 11:10 AM
Bertk's Avatar
Bertk
Originally Posted by emwolb
man, i'm happy to hear about these Khromewerks sweepers. the stock streetglide bars, suck, as they cause you to lean forward to reach the bars. they do me anyway, and at 6'4" tall, that shouldn't be the case i'd think. i find myself setting the cruise and twisting my shoulders so i can sit upright while riding with one hand. i gotta remember that. i'm assuming that the cuts are already there for the fly by wire throttle? i'll read the write up on it that bertk placed in his post. thanks again doc, you may just have saved the day for me.
The sweeper bars designed for TBW, have the cutout for the TBW wires to pass through, along with the hand control wires if you choose to go that route.
Old 08-06-2009 | 11:20 AM
Bertk's Avatar
Bertk
Doing the labor yourself, you could get away with a cost right around $100 for the bars and clutch cable.
Old 08-06-2009 | 02:52 PM
blackmicrophone's Avatar
blackmicrophone
6th Gear
Default Handlebars upgrade
I went with apes so I can't comment on the sweeps... BUT I purchased all the lines from hdbikeparts.com and was real happy with them and a buddy and I did the labor minus the time it took it wasn't rocket science. I know there are posts outlining how it is done. There is no way it is worth what the steelers are asking for the labor/parts etc. Plus I hear there is a month wait for clutch cables from Barnett.
My $.02.
Old 08-06-2009 | 02:56 PM
dawg's Avatar
dawg
I believe the bars are about $70-80 now. Were $63 when I bought them and the clutch cable retails for $33. You will also need a tranny side cover gasket for another $5-7. With the 09's it is my understanding you can just move a heat shield instead of dropping the exhaust to get the tranny side cover off so you won't need any exhaust gaskets.
Old 12-14-2009 | 10:05 PM
patriotmc's Avatar
patriotmc
Rodan, I'm thinking about doing the sweepers on my 07 Ultra. Were you able to use your stock brake and throttle lines (did you have to reroute them?). Also, where did you get the longer clutch cable and do you have a pn?
Old 12-15-2009 | 09:15 AM
dawg's Avatar
dawg
When I did the sweepers on my 04 I replaced the clutch cable. The brake line was fine. I originally kept the stock throttle/idle cables, but I felt that it was a little to tight and made the throttle sticky for my liking so I changed them out. The pn# for the clutch cable for your 07 would be 38649-07. Unfortunately, the -98 works up to 06 and -08 works on 08 and later. For some reason the -07 cable retails for something like $80 and my -08 cable is like $33. In any event it is the HD +3 cable used on sidecars so if you cross reference it in Drag for a +3 cable for an 07 you could probably get it for $40
Old 12-15-2009 | 11:49 AM
patriotmc's Avatar
patriotmc
Thanks Dawg... +3 or +4 sounds like it would work... may look at braided cables.
ral819
Milwaukee Eight (M8)
09-04-2017 05:18 PM
Ashnic
06-30-2017 09:14 PM
Big Dave
04-12-2016 02:25 PM
bcerame
07-10-2010 07:44 AM
Peppa1
06-02-2008 01:41 PM
Quick Reply: Handle Bars
